banffslider »
https://forums.nicoclub.com/banffslider-u146305.html
Fri Nov 06, 2009 5:35 am
Hey, a Local, awesome! Actually, I monoski, best of both worlds as far as I am concerned.The belt tensioner has a bolt on the bottom under the pulley to loosen and the main bolt pointing to the side to adjust, and when I did that, nothing happened. I ended up loosening the adjuster and using a big screw driver and hammer to get anything to move. Something else in there is still tight.
As for the amplifier, I am talking about the little stock one that is between the rear speakers, it has the same wiring harness that the deck came with. So was trying to run my amp off those wires but blew the fuse immediately as it is a 10 amp fuse. I have run a big power wire to the amp now, so now I can listen to tunes in my car that won't move. Actually, I am in the process of putting it all back together now, as it has started snowing heavily.I have a new thremostat and belts , except an AC belt as my AC doesn't work anyway.
