remove fuel pump 95 q45
Pontius
Car: Q45
How do I remove my fuel pump? I have loosened the nuts and removed the lines, but cannot pull it all the way our of the gas tank? Do I have to remove the gas tank? Also, it hummed before it died. Should I look for more problems than just the fuel pump?Thanks-Pontius
qsiguy
Car: 1994 Infiniti Q45 Turbo
You don't need to pull the tank. Did you remove the cover off the rear deck and back seat? Once you pull the rear deck and that small compartment it'll give you clearance to get it out.
Read this thread, down a bit is a complete write up of how to do it.
zer...age=2
Pontius
Car: Q45
No I haven't. I will try that-thanks. It looked like it was a fixed metal casing. I will look at it.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Try a search in Infiniti Online Mechanic where all posts of this type belong.
