remove ac compressor 98q45
froche22
Car: 98 q45
I'm having the toughest time removing the ac compressor because its such a tight fit! any suggestions anyone, please, please, please!
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
someone answer him, lol, I have this coming in a week or so myself.
Why you pulling it?
froche22
Car: 98 q45
The compressor went bad and I bought a new one but cant get the old one out.
paranoidjack
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1996 Infiniti J30
Looks to me (from FSM pics and instructions), after you remove the belt and 2 bolts on side and 1 on front, that it would drop down. What's in the way?
froche22
Car: 98 q45
there is a bar "not sure the name" but it looks like I have to drop the engine just to slide it out, was hoping there was an easier way.
paranoidjack
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1996 Infiniti J30
You referring to the tension rod? Here's another members pic of their old and new tension rods:
http://is.rely.net/3-99-13620-...Q.jpg
Has a circle with rubber bushing on the front end, and two large bolts on the other?
If so, just remove it. Just make sure when you reinstall it NOT TO TIGHTEN THE BOLTS THROUGH THE RUBBER BUSHING *TIGHT* UNTIL THE CAR IS ON THE GROUND OR YOU WILL DESTROY THE BUSHING!!!!!!
Only 3 bolts, should come right out.
froche22
Car: 98 q45
Ok thanks, I'll try it and let you know how it works out
paranoidjack
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1996 Infiniti J30
Good luck let us know how you make out.
froche22
Car: 98 q45
Hey Jack,Got it all done finally, I had to drop the sub frame as low as it would go and keep the engine elevated. I used 3 jacks what a nightmare but worth the cool air! Thanks for all your help
