Removal of PS and AC
93DriftMachine
Car: 93' Nissan 240sx
I have a 93 240sx and would like to remove the PS and AC. How can I go about doing this. Thanks for the info.
Xero
remove the belts, then wonder why you did it.
removing power steering in something like a corolla, or other small car, is fine, but S13s are not small, and having no power steering WILL SUCK!
you can do it if you want, but why make it more work for not a very usefull power increase. You'll never get to use it since you're fighting the car without the power steering.
but...to answer your question, remove the belts, unplug the lines, move the wheel left and right to get all the fluid out and cap the plugs.
A/C, get the system discharged and remove.
sanioll
Car: Nissan 240SX SE
Toyota Camry
Xero wrote:A/C, get the system discharged and remove.
Maybe i need to look at FSM, but HOW?? ^^
Once you remove it, are you able to put it back in and recharge it if you would like to sell the car??
How many horsies do you release by cutting AC compressors belt??
