Rob.Vegan »
https://forums.nicoclub.com/rob-vegan-u101073.html
Mon Jan 04, 2010 3:43 pm
I recently got a fix it ticket for my head lights and tail lights. After looking at multiple stores for a paint remover safe for plastics, I gave up and bought an aerosal can of aircraft paint remover.
Did the headlights and messed them up a little bit because I forgot to take the remover off and it started eating through the plastic
Most of that paint was off and then yesterday I decided to start on the tail lights. I couldn't find my old can of remover so I went out and bought a different kind (it was like a buck or two cheaper). The paint was falling off and I got super happy since the other remover was being a PITA. I wiped the excess paint off and rinsed the light.
Like 3 minutes later as the light was drying, it started turning white. I had already started on the other light so I was screwed. I tried rubbing, buffing, sanding, using the old paint remover (I found it in my trunk). Nothing was working. My lights looked hideous. Today I got stronger sand paper (800) and then cleared that up with (1500) then I clear coated it.
Dam, I was so pist after the results from the clear coat. It went from opaque white to nice and red.The passenger tail is still messed up from my experiments but it will be fixed soon. I only took a couple pics for comparison.
Before Clear Coat:
Driver Clear Coated:
Both Clear Coated:
