Z-bass »
https://forums.nicoclub.com/z-bass-u275169.html
Wed Jul 12, 2017 8:30 am
Yes, works for every injector !
Far easier to address with the plenum off (I did it with the plenum on - in fact, I have yet to remove it !).
Basically, the square "tabs" on the underside of the plenum block access to half of the screws holding the injectors in place. This is visually apparent. During manufacturing, the tabs could've been machined off (or not cast in the first place!), but that would be too easy !
Be CAREFULL ! Don't mill off more than is required to gain access from a reasonable angle, and maneuver the injector cover ! Test as you go ! You are getting close (to milling through) if you are milling beyond where the "tab" would be if it didn't exist (this requires some visualization/depth perception on your part) No, you won't be able access the "tabbed" screws straight through (you'll definitely mill through the plenum before you get there!) Although, in the pic, it appears as though the access is straight through, there is somewhat of an angle to access the "tabbed" screw. I used hex cap screws and ball-end hex keys to accomplish this. I still had to bevel some of the screw heads (versus additional plenum milling) for proper accessibility. I trashed a few of those crappy Phillips screws getting them out the first time - one required a screw extraction.
As I said, its a PITA the first time through, but after that, injector work is a breeze !
