Removal of front bumper
Nissan 350z / Nissan 370z general community discussion forum
iowas300z
Car: 1990 Nissan 300zx 2004 350z
going to take off the front bumper of my 350z this weekend.....wondering if someone could send me a diagram of the removal of the front bumper that would be great.
bkreitzer
Car: 2007 Nismo - Redline - #0550 - more info in my Bio
check out the service manual on the my350z forum. it is a large set of pdf files that are used by service techs. it looks a little involved. has anyone removed the front bumper before?
bkreitzer
Low_Cost
Car: 2004 Nissan 350z Touring Ed.
I've removed it before. Takes maybe 20-30 min if it's your first time. Less if you've had experience with other cars most likely.
It's mostly pop rivets and bolts. It helps if you've got a ratchet with a few extensions. This way you don't need to remove the wheel well when taking the bolts out from under them. (Also helps if you use the emergency trunk lift or some other lift to raise the car a few inches to get under the wheel well)
*edit* This is the diagram I used. (It's not nearly as complicated as it looks) http://www.350z-tech.com/zwiki...moval
Return to “350z / 370z Discussion”
