Removal of crank"sleeve"? wtf?
TD or Not TD
Car: 1986 Corolla GTS
i bought an automatic motor. and it seems to have a sleeve or bushing in the end of the crank where the pilot bearing goes.... its a little smaller than the actual crank hole so my pilot bushing will not fit in it.... i have to remove this correct?
and how do i go about removing it safely?
ilovecoupes
Yes you have to remove it .I believe its called a A/T adapter bearing. You can buy a pilot bearing puller. Or take a dremel to it.
TD or Not TD
take a dremel to the huge sleeve? and will a pilot bearing puller get behind that and actually be able to pull it out?
themadscientist
yes. I have yanked them out with a set of vise grips but a puller will reduce the cursing.
TD or Not TD
awsome thanks!
and a little offtopic, TMS what kind of turbo's do you have for your twin turbo project? i was looking for 2 turbos for my LS2 71 Vega GT and saw you might be backing out of the project. if you are looking to get rid of them and if you think they could support a 550-650whp v8 let me know. my e-mail is Turbosdabomb @ Yahoo.com minus the spaces of course.
themadscientist
They would support 750hp ish. IMO they are too small for a V8 application. I am still going to do the twin. I just can't afford to complete it right now.
Woods Crasher
I got mine off with some big channel locks and a small mallet
themadscientist
Woods Crasher wrote:I got mine off with some big channel locks and a small mallet
Daym, you are a tough mofo, I just use my right hand.
jt15833
Car: 95' 240SX
its a pilot bushing and it took me a solid 6 hours to get it out, the next one will not be as lucky. I tried dremeling/chiseling sides with little luck. Used a small tap and slide hammer.
I would say that this bushing and the timing cog are the two hardest things to remove. A slide hammer and tapping the cog/bushing is hands down the cleanest and surest method.
Woods Crasher
themadscientist wrote: Daym, you are a tough mofo, I just use my right hand.
Hand huh? Well I usually use my left pinky toe! I just use the channel locks when I'm lazy :P
TD or Not TD
Well i got a pilot bearing puller and a slide hammer tonight. wish me luck! this Nissan powered Toyota will live again soon!
themadscientist
use the schwartz
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
I see your schwartz is as big as mine!
themadscientist
lets see how well you handle it!
r34 gtr
Seriously, why do you not live within driving distance?! I would totally come raid your fridge and drink your beer. Oh wait, maybe thats why...
float_6969
He moved to a different continent to get away from your fridge raiding.
themadscientist
I don't drink beer. Rum baby Why does TMS live in Japan?great carshot chicksneighbors that mind their ****in business
TD or Not TD
well i tightened the **** out of that tool in the hole and screwed in the slide hammer.... Bam! 10 seconds later it was out. now i can get going on this thing again. too bad its been in the 30's for temp. lately.
BIGSAM06
Car: 1989 240SX COUPE w/ a CA18DET
i got mines off by welding a bolt on backwards and putting a big socket in between and the nut on the other end.. and i shot it w/ the impact gun..took me only 10 minutes!
