Apologies if this has been asked, but I could not find a solid answer anywhere.
I am a new owner of an 06 Z. It has an aftermarket turbo set up that I feel will just cause me issues. Granted, I love the power but I'm ignorant with FI and there are some problems with it already, hence my reluctancy to keep it boosted. The reason for this post is for advice on removal. If the turbo is removed, would a new tune be required? If so, is driving the car to the location of said tune safe? Is there a way to manually disconnect the turbo (safely) and see if that solves some of my drivability issues (Service engine light, turbo sputter etc) then connect it again, with out a re-tune or is that required?
I don't know the name of the turbo or where to find that info. I do have a revup Osorio in box, and extra injectors, I believe these are stock ones. However the ecu management system I have, I don't know how to use.
Lots of ignorance, but the car was a gift to me. So I wasn't able to do final inspection on a lot of things.
Basically, I'm in the dark here. The car overall is wonderful, but I'd like to protect my wallet a bit. Thanks for any direction you can provide.
