DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Wed Dec 25, 2002 3:24 pm
Fred, I've been out, just heard the news. VERY sorry that it's bad enough to total the car. The ECU and TCU are behind the carpeted kick panels just in front of the door speakers. ECU on passenger side, TCU on driver side. You have to feel around the carpet till you find the nuts holding the panels down. 10mm I think. There's a couple of clips too, but they should come right off with a little tugging. I've never done the TCU, but I will assume it's the same as the ECU. Once the panel comes off, the unit is right behind it. You can remove the harness connector first using the nutdriver. Loosen the bolt (I don't think it comes all the way off) and just pull or pry the connector off. Do it evenly--it's large and you don't want to bend any pins. Then remove the 2 screws holding the unit to the frame. Phillips heads, #0 I think. They're a lilttle stuck on with insulation. Pry a little if needed.Fred please keep us posted.
