Darius wrote:
2) I'm assuming nothing is wrong with the valve train and that you're just upgrading, correct?
3) Are you planning on replacing the valve guides or guide seals?
4b) Valve job might be a good idea for reliability, but I get nervous with giving my local shop technical stuff to do. My motor only has 40,000 miles on it so I don't think I've gotten to a point where it would be beneficial. That one is your call, and will probably be pretty expensive for minimal benefit.
My plan is to just freshen up the motor a little. Cams (aftermarket hopefully), either an RB25 turbine or if I have the funds HKS 2530 (I think that is the number of it...lol), gaskets, port and polish if needed, head work if needed, and probably rings depending on wear and what not. I am only shooting for about 250-300 WHP with will be quite nice for the Laurel. Right now, I have 205 stock at the flywheel, and I am guessing total with current mods about 210-215.
All I have as far as performance is Blitz filter, front pipe and exhaust. And I have never had it on a dyno. But I figure if the engine is rated at 205, I am pretty confident that 210-215 is a safe guess on HP.
Thanks though for your advise and information.
