I need some help in locating and fixing an issue. My sister owns an 07 Nissan Sentra SE and the trunk release button on both the remotes will not work. Locking and unlocking door buttons on both the remotes will work. We tried changing the battery on both the remotes and nothing. The pull cable under the seat works so the cable would not be the problem.
I tried to locate the fuse (if there is a separate one for the trunk) but was unsuccessful in location it
Please help and advice.
Thank you in advance!
