Thank you, very much.NISTECH wrote:The hatch does not have an auto release mechinism. You use the remote to unlock the doors then you manually open it with the lever. On other vehicles that use that system there is a solonoid and specially designed release latch to do that.
As far as the radar I am unfamilier with it.
Have any suggestions on a power source by the dome light/rear view mirror that powers up/down off ignition switch? This way the detector turns off when key is turned off...NISTECH wrote:The hatch does not have an auto release mechinism. You use the remote to unlock the doors then you manually open it with the lever. On other vehicles that use that system there is a solonoid and specially designed release latch to do that.
Hmm, thanks.I wonder if I could tap into the sunroof power supply.... Might be a bad idea I suppose....NISTECH wrote:There is no ignition power source at the dome light or rear veiw mirror UNLESS you have a compass or auto dimming mirror. If so you can tap into the power source for that.
