mrbean »
https://forums.nicoclub.com/mrbean-u11191.html
Wed Sep 15, 2004 9:38 pm
I've got it pretty much set up in my '89 manual s13 hatch. My alarm is the Clifford Matrix 3.5 responder.
You know, even in a manual 240, there's a neutral position sensor that can be relayed to either a neutral safety switch or a clutch bypass. Since my alarm came with a neutral safety switch (car won't start unless in neutral) I just hooked it to that.
I set up a seperate relay for the clutch override, to be triggered only when remote starting, so I still have a fully functional clutch when starting the car normally.
If you want to get REALLY fancy, you can relay the neutral switch to the Ebrake switch, so the car won't remote start unless the car is in neutral AND the ebrake is up. I think this takes out a lot of the danger of a manual remote start. Lemme know if you want the relay diagrams.
