TheMajesticKing »
https://forums.nicoclub.com/themajesticking-u167267.html
Mon Oct 20, 2014 7:32 am
I just had Viper Smart Start installed on my M56. It's not difficult nor is it expensive. I had a friend that works at an authorized DEI dealer do the install for me. The cost should range between $350-450 depending on where you go and if you're getting a good deal or not. If all you want is remote start the car, all that's need is: DBALL2, RF kit, and THNISS3 wire harness. Nothing else is needed. Most if not all newer Nissan Push-To-Start cars are considered "RSR" (Remote Start Ready) and the install is fairly simple and almost plug-n-play.
Cost of parts:
DBALL2 = $50
RF Kit = ~$100
THNISS3 = $50
Optional DSM200 or DSM250 for SmartStart (start from your phone) = $100/170
So that's $200 in parts for basic remote start. Considering it takes only about an hour to wire it up (thanks to the THNISS3) a shop should not be charging you more than $150 in labor but some shops are greedy. I actually planned on installing mine myself and I bought all of the parts only to find out that the DBALL2 is only programmable by an authorized DEI installer.
I paid far less than this since prior to October 1st, all you needed was the DBALL2 and THNISS3 and you could simply press the lock button 3x on your factory keyfob to start the car. Viper got greedy (as usual) and decided they were no longer going to support the 3x factory keyfob start since they want you to spend more money by buying an RF kit from them. And as far as warranty, I have never seen a warranty voided by remote start unless the installer did a terrible job and effed something up really bad. But considering it's nearly plug and play and there is no wire cutting involved, it shouldn't be an issue at all.
Hope this helps.
