Remote starter and auto headlights
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
polypep
Car: 2006 Altima Special Edition
So I installed an Avital 4113 with xpresskit DBALL2 on a 2006 Altima. Only installed the remote starter part and did no hookups for door lock / unlock.
Only one problem, where the auto headlamp does not switch off when remote starter timer is up and it turns off or if I interrupt the remote start and switch it off by clicking the remote starter remote.
Did some looking around and appears lots of people have this issue but no solution posted anywhere.
Can someone offer a trick to fix this problem.
dlg454
Car: 2006 Altima SE-R
Not sure if that remote start has the option, but I use remote starts that has the option to lock the doors when the remote start runs out of time. I woud hook up that lock wire to the drivers door pin. That way when the remote start shuts down, it will send a pulse to lock the door but instead makes it seem like the drivers door open then closed. If possible set the pulse for two seconds.
Return to “3rd Generation Altima Sedan (2002-2006)”
