remote start
abdow
Car: 1992 240SX
hello i have a 1993 240sx im thining about buying this starter. does anyone know how to install it. i tried before. instruction would be nice how to install SCYTEK ASTRA MODEL: 1000 RShttp://cgi.ebay.com/ebaymotors...A1318
Asmar
Car: 1994 Nissan Skyline
abdow wrote:hello i have a 1993 240sx im thining about buying this starter. does anyone know how to install it. i tried before. instruction would be nice how to install SCYTEK ASTRA MODEL: 1000 RShttp://cgi.ebay.com/ebaymotors...A1318
I wouldn't try to install something like that if I were you unless your good at electrical stuff. I had a Viper model installed on my car and I got stuck even with directions... Had to take it to a professional... I would recommend doing that instead...
abdow
Car: 1992 240SX
they charge alot!!!!!!
Stratokat
Car: 1992 240sx Coupe
hey i need to figure this out too! i have an auto page 900 and no shop around here will hook it up because its manual[which is understandable] but im not an idiot, and i wont leave it in gear.
does anyone know how to install it/ a place in so cal that will do it?
BIGTIMER_240
Car: 1989 240SX ka24de
^^^^^^^^^im in socal and i know about electrical stuff were are u located i had one of these autostart thingys but the took it off if u have the instructions i could hook it up.
Stratokat
BIGTIMER_240 wrote:^^^^^^^^^im in socal and i know about electrical stuff were are u located i had one of these autostart thingys but the took it off if u have the instructions i could hook it up.
yeah i have the instructions. i live in upland, but i drive pretty much all around so cal, where are you at?
long shot
Car: 89 240sx fastback
abdow wrote:they charge alot!!!!!!
there's a reason places charge a lot to do it. it's because you are messing with the cars electrical system when you do it.
Stratokat wrote:hey i need to figure this out too! i have an auto page 900 and no shop around here will hook it up because its manual[which is understandable] but im not an idiot, and i wont leave it in gear.
You may not be an idiot and leave it in gear but things happen. I saw some one use a rem start on a manual car (was made 4 an auto) and he started his car up and right over an enbankment and into a building. enough said.
On the better note however, I work at CircuitCity as an installer so I can walk you through doin it most likely. How ever you should really look into purchasing a proper remote start for a manual transmission to be safe. I purchased mine from Compustar for about $200 and it is worth every penny, it does both auto and manual just by changing a wire.
Any Way on to the important parts. abdow U r doing just a remotestart not alarm correct? Does your car have factory security? Power locks? Power Windows?
I ask these things because I can pull up the specific wires n locations for you wen I go into work tonight and then try and give u a better writeup tonight.
I Will Look up the 93 240sx then.
One last note****DON'T GO CHEAP ON A REMOTE STARTER BRAND BECAUSE IT LOOKS LIKE A GOOD DEAL. YOU MAY BE HIGHLY RISKING YOUR VEHICLES ELECTRICAL SYSTEM TO PROBLEMS AND ALSO PUTTING YOURSELF AT GREAT RISK***
Look for a reputable brand. Like I said, I've worked with Compustar and own one. They are great choice and designed specifically to do manual transmissions so that the car will never start if left in gear or no e-brake up.
-Disclaimer. Since I am not preforming the work personally and this is your own vehicle please use the advice i give you in consideration,and note that any work you preform on your vehicle is your work, not mine. Therefore in no way should I be held accountable for any mistakes made along the way.-
However I would gladly help you troubleshoot things if you were to run into any problems.
Will post wiring info later on after work. If you guys want me to make a DIY or How To post lmk/.
BIGTIMER_240
i live in huntington park
Stratokat
would it be helpful if i scanned the instruction pages that told how to wire it up right and post them for you?...yeah... thats what i'll do...
abdow
Car: 1992 240SX
everything in the car is manual. but i was going to convert the doors to automatic. so the door,window r both manual. that would be nice if you could help us out.actually i think i have 1992 and not 1993 240sx
Stratokat
You can click View Image to see the pictures clearer, the forums downsized them a bit so they are sorta pixelated
Modified by Stratokat at 11:44 PM 1/15/2009
motoman399
Car: 98' wrecked (RHD coming soon) 240
im installing a remote start in my car also. the only thing that keeps shops from not installing them into stick shifts is that they can start in gear. well on the 240sx there is a neutral safety switch on the transmission that tells when its in neutral. my question is, does anyone know where to find this wire on an s14. i am good with electrical, this is the only thing i cant find. thanks
found it, its a green/orange wire. number 36 on the ecu plug.
Modified by motoman399 at 10:06 PM 2/9/2009
Stratokat
would the neutral safety switch wire on the ecu be the same for a red top??
and yeah, i need some help wiring up my remote start. could you tell/show me where you installed each wire??
im not bad with wiring, but im lost when it comes to this.
motoman399
get a volt meter and test it. thats what i did. cant hurt, and i would imagine that its the same but have never had a sr so i couldnt tell you for sure
