Remote start, starter keeps running after vehicle is running!!!
Post all your Nissan electronics, car audio and stereo questions here!
240sxGT
Car: 97 Nissan 240SX SE
98 Nissan Maxima SE
93 Subaru Imprezza
Ok so I have a Viper 791 alarm installed on my 97 240sx. Everything seems to be working except that when the remote start is used to start the car the starter will continue to run. The only thing that shuts it off is when I release the e- brake. The e-brake is tied into the system as the neutral safety because it is a 5 speed. I have checked tach signal, learned tach signal verified, checked the settings to make sure it was for tach check and also changed the crank time none of which makes a difference. Any ideas what I need to do? Please please help this is the only thing holding me up on a long awaited project. Thank you.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
That's strange that it would do that with a learned tach signal. Maybe try moving it to an injector, relearning it, and seeing if anything changes? Also, I would recommend going to the neutral safety switch instead of the parking brake.
240sxGT
98 Nissan Maxima SE
93 Subaru Imprezza
Ok I will give that a try tonight and let you know. Thank you very much!
240sxGT
98 Nissan Maxima SE
93 Subaru Imprezza
Well made the changes as suggested, but still getting the same result, cars starts and starter continues to spin, I did verify tach signal learned again and also tried changing to reading voltage settings instead of tach, same result. So whre do I go from here, thanks very much for your help
zerepdivad
Car: '90 240sx . '02 Lexus IS300
Have you tried starting the car by key and doing the remote start take over and seeing what happens?
240sxGT
98 Nissan Maxima SE
93 Subaru Imprezza
No I have not, I will have to look it up not sure how to do it. Thank you
zerepdivad
Just start the car by the key then activate the remote start the same as you normally would and then you shuld be able to remove the key. ANd if it still keeps just cranking then you've either got the wrong wire hooked up to the starter wire or you've got a bad unit. When you say it keeps grinding is that indefinitely or it keeps grinding for just a little bit? And you're positive tach was learned correctly right? You held the valet switch until the led lit up?
240sxGT
98 Nissan Maxima SE
93 Subaru Imprezza
Yes I have learned the tach correctly and verified several times. When the remote start is used to start the car the starter does not actually grind but rather continues to to spin(whining noise) indefinitely. When I had the neutral safety switch hooked up to the e-brake, if I would put the e-brake down then it would stop the starter from continueing to spin. I have since then moved the alarm neutral safety switch to be tied into the neutral safety switch on the car so I can no longer can stop the starter from continuing to spin it will just run and run and run. Thanks again.
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
Did you hook up the brake wire? That will stop it from trying to start if it is. I'm not quite sure what is going on, but I'll see what I can dig up.
240sxGT
98 Nissan Maxima SE
93 Subaru Imprezza
Thank you very much gentlmen!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Got her fixed, apparently the posting of the wiring diagram that I was using was just a little different then my car. I switched 3 wires today and everything seems to be just fine now. Thank you very much
zerepdivad
Well next time use a multimeter....... and VERIFY the wires correctly..... Kind of figured it was something like that. But nice to know you got it. let me guess 12volt.com diagram?
benjimatt
Hey what wires ended up beign incorrect. I am having the same exact issue???
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
Most likely a starter wire and ignition wire would be my guess. Did you meter the wires or just listen to a guide you had online?
