Remote programming instructions
Big Tone
Car: 1993 Infiniti J30
I want to buy another remote for my J30 and see there are sellers on eBay that are auctioning them for a reasonable price. I have verified that the FCCIDs are the same as mine, but need to know how to program it. Does anyone know how to do this?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Big Tone
Thanks!
Prinzess
Car: Infinity J30 1993
Did anyone repond to you? did you find out that information i need to know too
elwesso
2007 BMW M Coupe
Click the link......
Prinzess
i didn't see it thanks!
Prinzess
Wes, So if the remote is operating correctly the windows will come down when i hold the unlock button? if so mine does not work i can open the doors, the trunk, turn on the lights and sound the alarm but that is it. can i use the instructions to reset it and then maybe the windows will come down?
Big Tone
What do you do to sound the alarm and roll down the windows? I didn't know either of these were options!
Big Tone
^^^Does anyone have an answer for this?
InfinitiFreak101
Car: 1997 J30t
Another question: I just got a keyless nob from ebay, it doesn't beep when I press the buttons. Are the keyless nobs supposed to beep if you press the buttons? Does this mean my battery is dead?
Big Tone
New issue: I got a remote off of eBay today and was able to program it with no problem. However, now the original remote won't work! I followed the directions to a 'T' with popping the trunk, locking the doors, entering and removing the key 6 times in 10 seconds and then hitting the lock button. That seems to transfer the programming from one remote to the other. I then tried to program both at the same time but repeating steps 4 and 5 per the instructions, but it didn't work. If anyone cal tell me what else needs to be done I'd greatly appreciate it. Thanks!
Big Tone
OK, I think I know what the problem is. Looking in the service manual it says when using the remote programming instructions and entering a new remote code while in "entry mode", the previous 3 remote IDs will be deleted. It says that if you want to add a remote (not replace it), the code needs to be entered manually. Does anyone know how to do this?
elwesso
2007 BMW M Coupe
What you do is repeat step 4 and 5 (manually unlock and lock) then press the lock button on the remote...
Big Tone
I did that but it didn't work. I tried about 10 times.
elwesso
2007 BMW M Coupe
Many people say they cant get it to work... Im not relaly sure what ot say...
Big Tone
I was able to program it, but as I said, once I do it deletes the existing remote's code. The instructions for the J30 appears to make a distinct difference between "entry mode" and entering the code "manually". Per the instructions, when you add a remote code while in entry mode, it will delete the 3 previous codes. I'll go step by stem giving explicit details regarding what I did. Let me know if there's something missing or wrong:
1) I popped the trunk using the trunk release on the driver's side door2) With all doors closed on the car, I locked them using the power door lock located on the driver's side door3) I inserted and removed the key into the ignition 6 times, leaving it out on the 6th time4) I manually unlocked and locked the driver's side door by unlocking and locking the chrome door lock on the driver's side door5) I then hit the door lock button on the remote I wanted to add. The car responded by sounding the alarm6) I again manually unlocked and locked the driver's side door by unlocking and locking the chrome door lock on the driver's side door7) I again hit the door lock button on the second remote I wanted to add, but got no response.
Please let me know if there is someting missing or wrong in what I did. At this point my only other option is to have the dealer do it if I can't figure it out. Thanks for your help.
InfinitiFreak101
Car: 1997 J30t
What year j30 do you have?
Big Tone
gabarsingh76
Car: 95 J30
will the link work for 95 j30??
xxcrashxx
Car: 95 Infiniti J30
it doesnt say it will....
but try fuzzy catshttp://fuzzycats.com/j30_diy.htm
this one doesnt say its specific to any year. i just wish my car would make a noise when it locked, like an audible one. :'(
fourdrinie
Car: 2019 Q50
Big Tone didnt do the last step to complete the ID enter mode by operating the driver's side door. (Just open the door)
gabarsingh76
Car: 95 J30
thanks the link worked great!!!
Gerardjg
Car: 2007 Cobalt LS
2011 Hyundai Accent
2016 Kia Optima
Here is a copy of the technical service bulletin forreprogramming key fobs.
http://home.cfl.rr.com/dandgsystems/new_page_5.htm
