Remote problems...
jasonhirt23
Car: 1993 Q45
If your trunk button does not work inside the car on a 93 Q45, will trying to program a new remote not work correctly or at all? I can't seem to get the after market remote to work at all.....AARGGG!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
FCC numbers must match then remote must be associated with car security per FSM.
Didn't know 1993 had remotes. Thought 1994 was the first.
jasonhirt23
Car: 1993 Q45
Well, the speedometer cluster has the security light on the right hand side so I assume it has security feature. The only problem is if the trunk button in the car does not work, will it void you trying to get the remote programmed?
Q45tech
ASSUMING does not replace reading FSM or owners manual.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
jasonhirt23 wrote:Well, the speedometer cluster has the security light on the right hand side so I assume it has security feature. The only problem is if the trunk button in the car does not work, will it void you trying to get the remote programmed?
Reprogramming the remote will not void your warranty, Do you have one?
Did you check the trunk lock button in the glove box? Does the trunk opener switch on the door work?
NightRiderQ45
Car: 1998 Infiniti Q45
Really...warranty of a 93
Infinitiguy19
My bad I skimmed his post and he said something about voiding something, but Hatian King had a warranty on his 1992 Q45 (Aftermarket warranty).
jasonhirt23
Car: 1993 Q45
I did check the glove box. Tried it with the switch both ways.
