thats wut i was thinkingEikon wrote:wow... with radiator hoses that long, you might not even need a radiator.
I thought about that option but I later on decided that I liked the idea of moving it to the rear more.s14 2510’s wrote:Why not just move your engine back into your firewall like 3-4 inches. There would be more than enouf room for your radiator and you would get way better balance with your car. I am going with a dry sump so i have to redo my oil pan anyways so its no big deal for me. my fuel cell and bat are going in my trunk.
Yeah, but when the electric one goes, it gives no warning. With the mechanical pump (pressure gauge was a good idea by the way) you'll notice a drop-off in performance or leaking when it's time to replace it. The electric pump is also going to put more strain on the stock alternator. Combine that with the electric fans I'm sure you'll need to run. Something to consider.s14 2510’s wrote:One less thing to go bad if you go with an electric one.
I don't know how much in volume it moves. I am pretty sure I can find out though.themadscientist wrote:B, how many GPH does the engine-mounted water pump move? In my research on air-water intercooling I have found a few marine bilge pumps that move decent amounts of water and can run continuously.
