First off, this is what I am doing when I to program the codes:
- Unlock Driver's door (sometimes all doors)
- Open trunk (either using the remote release on the door or by key at the trunk itself)
- Get in, shut driver's door
- lock the doors using the lock lever on the driver's door (tried it using the lock switch too)
- put the key in and out of the ignition 6 or 7 times (have tried both, as well as many as 8 or 9)
- unlock driver's door using the lock lever
- lock driver's door using lock lever
- press button on remote
- Repeat the last 3 steps with the second remote
- Unlock driver's door, open it and get out.
Is there anything I am doing wrong in these steps? Is the car supposed to give you some indication that it has erased the existing codes and is ready to accept new ones?
As far as testing the systems goes, I have checked everything in the FSM:
- Remote batteries are both good, voltage verified using a multimeter
- Power and ground to the LCU07 remote controller box are good
- Continuity between the antenna plug and ground as required in the FSM (This is tested on the harness side, right?)
- Ignition switch circuit works because the seat and steering wheel automatically adjust when the key is put in the ignition
- All door switches and the trunk switch work (verified in Mode II - Switch Monitor)
- Both remote lock relays located behind the driver's side kick panel are good. Verfied with a 9V battery and multimeter
- LAN diagnostic mode reports code 11 - no problems (LCU07 problems show up as code 54, 55 or 56)
I really feel like I'm at a dead end beating my head against a wall and it's incredibly maddening because everything looks like it *SHOULD* work.
What else should I check? Is there anything wrong in what I am doing to program the codes? Is there anything I'm missing?
