Svenfran »
https://forums.nicoclub.com/svenfran-u83405.html
Tue May 31, 2011 1:56 pm
95 Maxima SE, manual trans, 206K miles. I just replaced the ignition key switch/cylinder a**'y because it was getting loose and the "Start" position was intermittent. Now I have no remote control functions from my keyless entry devices. No power door locking/unlocking; no window-down function; no panic button; and no remote trunk unlock. Not sure if this happened immediately after replacing the ign switch, or a day later. I have checked some fuses, but not all.
From my factory service manual, I did some checks of the "Multi-remote Control Unit" power and data connections in the trunk (also described as Local Control Unit, or LCU05) and have found no problems so far.
I'd appreciate any suggestions as to the logical diagnostic order. Should I just replace the LCU05 in the trunk (which apparently serves as the "receiver" for the system) and hope for the best? Or something else? The service manual is pretty hard to follow and doesn't really lead me down a logical diagnostic path. Any help is greatly appreciated.
