audtatious »
https://forums.nicoclub.com/audtatious-u2438.html
Thu Dec 29, 2005 6:43 am
Interesting. I started going through diagrams again and I wonder if I was looking at the wrong year.
The 1999 models refer to the BCM (Body Control Module) and not a Time Control Unit. The BCM is located behind/below the radio (must remove radio and ash tray). From what I see, the LCU's (Local Control Unit which is each doors window/lock switches) communicate to/and are slaves of the BCM. When nothing is happening, the BCM "goes to sleep". When key is inserted, it wakes up and wakes up the slave LCU's.
The Multi-Remote Control Unit (LCU05) is located in the trunk on the right side and has a direct data line to the BCM. Signals via your key fob are received via the MRCU which, in turns, wakes up the BCM.
So, I would check the MRCU first, then proceed to the BCM.
