drbill »
https://forums.nicoclub.com/drbill-u58974.html
Tue Mar 06, 2007 5:24 pm
I've started experiencing the typical dry solder problems with my '94 J30. I've already disassembled and resoldered the headlight relay to fix the problem with it. And the radio is sitting in a box ready to be sent out for repair.
Lately, the car has becomed possessed, however. Several weeks ago, after leaving a parking garage, the alarm system went off while I was driving it. It was erratic and random. I think the person in front of me thought I was trying to flag them down, what with my lights flashing and the horn blowing; they pulled over. It just quite and didn't reoccur.
Then, today, while driving, the emergency lights flickered for a few seconds, then the doors unlocked (and wouldn't stay locked), and then the horn started. It stayed on for a few minutes while I'm driving down the highway. The high beams flashed occasionally. Then it stopped. During all this, the other electrical systems, such as door locks and A/C, worked fine. The exception was the cruise control, which would no engage.
The interior light stays on, if I leave the switch in the "door" position, so it's switched off. The door key hole light is constantly on, as is the key illumination light on the steering column.
I'm thinking it's either the Remote Control unit or the Theft Warning unit (or both). Since the Remote Control unit looks easier to get to, I'm planning on pulling it first, and see if it can be openned and re-soldered. I'll check all the harness connections at the same time.
Any ideas or suggestions?
It is possible that the alternator's partially to blame. I'll have that checked out in the next day or two.
