That's why I haven't done it to my Q45. On alarms, it's all about the installer and his experience. Try to go low bidder and you will get burned.qship96 wrote:I once thought of adding a super fancy aftermarket security system/remote start but the thought of someone cutting/adding wiring to the already complex Q wiring/LAN system made me think it may not be a good idea.
So it's not a completely bad idea? It's been getting colder out here and I'd love a remote starter.Q451990 wrote:I have done it on my Q and it's a pretty complex installation if done correctly. You have to splice into the starter wires, brake circuit, tachometer, constant 12v, switched 12v, etc. On your '97 you would need to deal with the chipped key (or lack of it being there during the remote start) It took me a couple of days.
If you are very comfortable with automotive electrical systems, you will be fine - but it's not a step x step deal that we can walk you though here. You need to have some knowledge about electrical systems.
Heath
I think it's a great idea if installed correctly. If you have a friend with automotive electronics experience and the FSM it should be fine. If you're paying someone to do it I would look for the best alarm installer in your area...Haitian_King wrote:Would someone with electrician's training and an FSM be able to handle it?
