demollitionman »
https://forums.nicoclub.com/demollitionman-u206546.html
Thu Sep 19, 2013 2:33 pm
Basically what the tittle says, My big end bearings have failed or are about to, tomorrow I am gonna drop the oil pan and check the severity of the damage, basically it starts to make contact(sound) around 3k rpms to 4k under full throttle so maybe its still early enough and I could get away with a polish but i doubt it
anyways to keep it short I live in Puerto Rico its a pretty small island, I can't find a local ca18 or ca16 crank or block or anything related so my options are reman crank, get a used crankshaft from you guys or ebay or take it to a local machine shop which there is a high chance they will screw something up(If its not a rotary there is a big chance for a screw up), I had a talon tsi awd before this and when i was building my spare engine I took it to my local machine shop and basically they gave me the 7 bolt rod bearings on a 6 bolt crank(different rod journal diameter) and when the assembly would not rotate on my engine stand they said it was my fault lol
tl:Dr
Are remanufactured crankshaft good? are they even forged as stock ones
