Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Fri Apr 21, 2006 4:30 am
What ever you do make sure you get a written specification of the radial/axial wheel run out and a specification as to maximum weights required to balance............make sure that meets the oem wheel specification!
Wheels can be damaged in transport and you might not see/measure it until too late to return! Heck most aftermarket wheels don't meet specs brand new when shipped to retailer or leaving factory.
A proper wheels should not require more than 5 grams inside and 5 grams outside to balance to 0/0 grams on the fine setting.......careful most shops use the secret coarse setting to avoid the truth........it rounds down to zero from 7 grams or a 1/4 ounce.
