ddgsxr504 »
https://forums.nicoclub.com/ddgsxr504-u24314.html
Wed Feb 02, 2005 6:31 am
NA is the cheapest and easiest way to go, you will have more power through RPMS because you wont have to wait for your turbo to spool up. I have seen a lot of catastropies when people boost KA's, if you don't have the time and $$ its not worth it because if you happen to get boost creep, BOOM, the bottom end of a KA is really weak under boost. IF you are going to boost your KA you will need new rod bearings and all the other stuff, fuel management/upgrades, intercooler, turbo manifold, BOV, too much to list. IF you go NA all you need is cams, tuned ROM, header, exhaust, slightly upgraded ignition and a good suspension set up. 200HP may not be much like some people said but with a light car and Suspension you will have no trouble whipping that S-13 around a track. If you have time and money+patience, port and polish the head too you won't be sorry.
