pippen99 wrote:He didn't solve the problem. He just transferred it to a different system. Personally I would rather have a problem with starting the car to diagnose than a problem with the brake system that rears it's ugly head while trying to whoa down a two ton car from 60 mph!
Actually I don't think I did either. First off I doubt that the relay marked ACC brake would be the cause of me not being able to stop the car. Still not sure what it actually is but since I have the laser type cruise control I am thinking it may be associated with it.
This morning it did its thing again. Now after doing this I started paying particular attention to exactly where I pressed the button. So today I pressed it at about the 8 o'clock position and it started each time at that position. Probably not it yet but I need to be able to figure this out on a consistant failure basis or hopefully it just fails completely.
If this is it then I'll press Infiniti to replace the switch even if they can't duplicate it. If not then I'll press them to start doing more than looking at codes which up until now I think that is all they really looked at.
Perry
