Relays?
Flamereka
Car: 89 240sx, 96 240sx,98 subaru 2.5rs, 07 wrx
What do your relays byt he ecu have on them are they 3-5 1-2
with the 1-2 being a coil and 3-5 normally open?
I have some in my skyline fusebox that weren't being used and they fit but i'm not sure if they are correct. Are they?
DrifterTom
Car: 90 rb20 coupe
i think nissan color codes their relays. as long as your not color blind your good to go
Flamereka
The plugs are green which should have green relays in them. The ones from the rb20det fuse box are blue and are the ones with the 3-5 1-2
Upon looking in the stock ka24e fusebox I see 2 green relays that are 3-5 1-2
And the only difference I can see between the blue and the green ones are the colors.
I appreciate all responses but if you don't know or aren't positive please don't answer. I've noticed that everybody assumes stuff in the Rb section of Nico. There are tons of threads with responses like "I believe, I think, If I remember correctly,etc"
I'm in the middle of my swap and there is alot of bad information on here, but again alot of very good information which without I wouldn't be this far. Its just annoying to be going by assumpstions.
