relay rapidly clicking: help please
accel junky
So i was trying to start my Rb25 and while switching wires back and forth trying to get the Maf hooked up right the middle green relay (fuel?) started rapidly clicking and the injectors were clicking as well. I switched the relay from the left of it (same kind) and it still clicked.
Any Ideas? Please help, its almost running.
JonPowell
Car: Cars, Music, My family
Check one of the AT LEAST other 2 forums you posted this on.....
240+civic=pimp
Car: s13/rb20det, 2002 WRX, 1994 Yamaha fzr600
is it the fuel pump relay that is clicking?Do you need to sdisconect the battery to stop it?
accel junky
Its the middle green one. Even if I switch tops with the one to the left of it, it still clicks rapidly.
240+civic=pimp
Is the red/white wire comming out of the lower harness connected to the alternator?
Make sure this will blow your alternator.
This most lickley is your problem.
BoostFab
Car: S13cp, S13fb, S14z
try swapping out the realy with another one...
accel junky
BoostsFed wrote:try swapping out the realy with another one...
I did, the one next to it with the same part number. It still clicked but far left didnt click no matter what was switched on to it.
240+civic=pimp
did you check the wiring that i suggested?
