dfddfd2 »
https://forums.nicoclub.com/dfddfd2-u136200.html
Thu Dec 03, 2009 5:44 pm
Sounds like you may have a toasted ECU. One of the first things the ECU does is turn on the ECCS relay, so it's getting that far, but if something goes haywire in the ECU and it quits running, it resets itself, which turns the ECCS relay off. After the reset, the ECU turns the ECCS relay on again, but craps out again, resets again, etc. etc. etc. It all happens very quickly so you hear the relay turning on and off rapidly, thus the "buzzing" sound. First try re-seating the ECU connector. If no go, open up the ECU and look and smell for any burnt areas on both sides of the board. I hesitate saying to try another (borrowed maybe) ECU until you know if/and/or why the problem started.
Dave
