Post by dgms240 » https://forums.nicoclub.com/dgms240-u55469.html Tue Aug 14, 2007 9:46 am
Post by vancouverbc » https://forums.nicoclub.com/vancouverbc-u10923.html Tue Aug 14, 2007 12:29 pm
Relays click when they get power. Your ignition relay doesnt have anything to do with starter. Do you have a theft warning relay? Not sure if that is standard. The power is coming from ignition switch and then to interlock relay. You will have to find out how far the power is getting to know what component is faulty. THere is also a clutch interlock switch on your clutch pedal that needs to be checked.dgms240 wrote:ok, i think ive narrowed my starting problem down to a relay. first off i have a 95 240sx se 5spd. theres no power getting to the starter when i turn the key. i hear a small click from the drivers kick panel. my question is do i need an ignition relay or a starter cut-off relay. these are the two that they had at napa. also i know where the ignition relay is located, but where is the other one?
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
