relay problem in my 200sx
monie240
i have a 96 200sx and i keep blowing relays so when i take out my key the motor still runs and my dash lights stay on but the rest of the interior electronics shut off the only thing i have hooked up thats electronic is dual 12 inch fans but i checked that and as far as i could see it wasnt it some1 please give me an idea
projectKERMIT
Car: 1996 nissan 200sx SE
hey man how's it going, I also drive a 1996 nissan 200sx and i am haveing similar problems with mine. one day i got into it and it would not start so i went to check the battery and found a large amount of corrosion around the terminals i cleaned them up and when i went to connect the negitive cable the relay started makeing "popping" noises i finnaly got the car started, and as I started driving i relized that none of my gauges, heating,cooling, radio, turn signals, power windows, locks and anything else electric was not working. i later found the problem coming off of the battery. there are two wires coming from the positive terminal one is black i think and the other is red/white the red/white one goes into a fuse block try checking that wire all the way back to the ignition you might find a short somewhere. i hope that this works for you, if it is something else please let me know what it is for future referance
