I THOUGHT when I brought my M35 to my mechanic that1. my headlight bulb was blown.OR2. my ballast no longer worked. Blinkers worked fine, halo lights worked fina as well as the high beams all fine.Everything BUT my passenger side HID low beam headlight. But..So the thing my mechanic said I will need to purchase is a Relay ((i think that is what gives power to the ballast to run the headlight)) RIGHT??? Well, I was wondering if anyone else has had this issue or something similar to it?Also if anyone knows WHERE the relay is located
Thank you!
Modified by XxLisaJazminexX at 11:07 PM 7/18/2009
