Relay harmess question last hope....
Vilmenay
My NA 90 300zx is still not starting. it will turn over but not start. Thus far I found finding that there is no power going to the EGI relay or the Ignition Coil relay. The FSM manual says that I should have 12 volts of power to trip them. when I jump the ignition coil relay and spray starter fluid the car will run for several second on the fluid. When I jump both the EGI relay and Ignition coil relay the car won't even turn over. So I know the ptu working because it's new with the wiring, Is there a power connection between the CAS and the EGI relay? I don't know what else to check. And yes I used new relays.
Zwicked
Car: 1990 300 ZX tt, 1990 240SX
I sense your frustration and understand completely. Not to hijack this post, but if you don't get the answer here, post this one http://www.twinturbo.net. There are several people who's' business are exclusively Z repair that can likely steer you right.
