Relay for Tilt Motor
friedrice2841
Car: 1992 Infiniti Q45
Recently had just the tilt motor replaced on my 92 Q45a. Steering wheel still will not go up, but will go down. The machanic who put it in told me that there is a bad relay, and that the relay is in a plastic sealed box near the parking brake. He told me that you cannot just replace one relay, you have to replace the box. He told me that the box was an enclosed plastic box.What is this box called? Is it expensive? Are steering column relay issues common?Please help. Thanks
Tim Rice
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
I'd be a lot more suspicious of the slider switch for the steering column positioner.
He may be talking about the BCM, but you need to study the wiring diagram.
Experienced Infiniti technician, I presume?
Modified by maxnix at 4:57 AM 3/15/2007
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Ive never heard of the motors in the steering column failing....... Id check something else, like the switch...
