Relay for Led's
duffman8189
Car: Altima Coupe
Does anyone know how to have a relay switch to turn on/off Leds that run from the housing of the headlights and the front of the bumper? Im trying to be able to cut the power to LEDs, anyone know about this?
sjbaltimaproject
Car: 2008 Nissan Altima coupe 2.5s
your gunna have to run a power wire from the battery to the inside of the cabin. easiest way to do that is by going the the firewall inside the wheelwell on the driver side. if you take out the wheel well you will see where all the wires come out of a hole lines by a rubber water proofing. that seal can be moved over a bit to squeeze in a screw driver or something long and narrow. before trying to get that through, go inside the car and get under the steering wheel and look up and find where the clump of wires goes through into the wheel well. there will be a slit in the fabric that was cut to allow the wires to go through. tape the end of your power wire to the end of your screw driver and push it in between the seal and the metal hole and try and find that slit in the fabric. once you find it and get through grab the end of your screw driver from the inside of you car and untape the wire and pull it through. after that its just a matter of wireing your switch but your going to have to have another wire that goes from the switch to the lights now that i think of it, so when you feed your wire through make sure you have a wire that is spliced to the lights positive and the power wire from the battery and then just splice them to your switch. now if you feel like making things really easy and saving your self alot of time you could just buy a wireless remote switch that you could just mount your reciever inside the engine compartment and wouldnt need to go throught the firewall at all. i have one for my interior leds and i love it. youcan get em on oznium for like 30 bucks. good luck n let me know how it goes
