(Relay?) clicking in Rt Frnt Fender. Drained Battery?
Dave 1854
Car: 1996 Q45
Hello!
1996 Q45 owners, which my wife loves. New to us. Well cared for.
Woke up to battery being dead. I thought I left lights on, but wife found it, and we don't think lights were on.
So I put a trickle charger on it. After a few minutes, the charger light started blinking, and it sounded like a relay was clicking near the battery....in the fuse box?
(I disconnected neg terminal, so the battery can charge. )
Key was out of ignition, so I'm wondering what electrical component is energizing a relay w/o key? I puilled the fuse cover off and tried to feel for the relay clicking. Couldn't determine which one.
Power antenna? We've been having problems with the antenna going up or down, and I know it operates after key is removed from ignition.
This reminds me that after starting it, there is a series of clicking going on in/near the right front fender, which eventually went away, so we thought "old car." Maybe these are related?
Thoughts????? Appreciate any help! :confused: :confused:
goody90q45
Car: 1992 Infiniti Q45 (sold)
I had trouble with a couple of my Q's with the ABS relays in the black box in front of the ABS unit. Was the ABS light on the last time it was driven? When either of these relays stick they'll click until they drain your battery. I couldn't find aftermarket relays and had to buy them at the stealership.
Dave 1854
Car: 1996 Q45
Thanks for the quick reply.
Boy I feel stupid. I DID leave the lights on.
ONce I hooked up jumper cables to it, the lights came on a bit. So I got acquainted real well with the light switch.
Also, I believe the clicking relay to the outside of the fuse box was the alarm/horn system trying to alert. Apparently, I triggered it when I was fiddling around with it (again the wife's car...not real familiar with it).
thanks again...
