soo, a s14 weighs roughly 3000 lbs with driver, equalling 1361 kg.and roughly, each tire is taking 1/4 of the weight so 340kg per tire (this would be kindof a skewed figure since more would be put on the front driverside tire etc etc. but i dont have all the numbers so this will have to work for now
SOOO.. if i get wider tires, all that will happen (disregarding the small increase in weight from heavier tires) is that my contact patch will get wider and narrower, but overall have the same area. as far as i can tell the only benefit of wider tires is that they heat up more evenly because there is physically more rubber, is this right?
so the only way to increase grip would be to a) change the compound of the tire to somthing softer, that grips better as it heats up, or b) create more downforce aka pressure on the tire via spoiler.
the conclusion that i have come to is that wider tires are only useful for when you are doing extremly heavy driving for elongated periods of time, because the only benefit of them is that they spread the heat evenly throughout the tire and dont melt as quickly. So i *think* a tire around 205-225 would be good for me since i dont do endurance racing / road racing / etc. and i should just choose the softest compound that my wallet can handle, given the rapid treadware. the only thing left would be creating downforce via spoilers, which is a completly different animal because i have no idea how to calculate how much downforce is created by any spoiler.
since i think i have one half of the tire equation figured out, does anyone know where to find information about front spoilers, wings, canards, and the like, for use on street cars? i can find info on F1 stuff but none of that really applies to my car.
anyway, please tell me if i have anything incorrect or whatever and point me in the right direction
WOW big post, thanks anyone who has the balls to read through the whole thing lol.
