Relation between tire size and gearing
groundhogday1976
Car: 2015 Altima 2.5 S
Okay, I know that increasing your tire diameter will make for higher gearing, and decreasing it will make for lower gearing. Is there a formula I can use to plug in say, fifth gear, final drive, and tire diameter to get gearing so I can tell how much changing tire heights will change things?
sultan
this one shows what your rear end gearing, and speedo error are: http://www.c5-corvette.com/tirecalc.htm
