tollboothwilley wrote:I doubt there is anything that he can see a problem in other than the end links. Unless the bushing brackets are loose. Either way, its a fairly simple fix. Take off the back tires, jack it up and tighten the bracket bolts. Replace the endlinks with the revised ones. I know that I put those on when I went to Stillen sways and it only takes a few min once you have the car in the air and tires off. Be sure when you tighten down the endlinks that the inside nut isn't spinning or else you won't get it torqued down right.
Thanks for the pointers, I always prefer to do the work myself, but the mechanic is a friend who seems to be pretty good so far?!? He'll give me a quote before starting, and of course, give me the option to install myself.
I'll hear from him when the links get in and let you know what I do, thanks guys, oh, and Nate, I updated my sig just for you buddy!
Sentientbydesign wrote:BTW, change your sig already!!! NRG?
