Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Mon Nov 25, 2002 2:05 pm
When you can move the wheel left and right top/bottom in and out , it will be the wheel bearings.Left and right only no top/bottom motion it will the the tie rods end or inners or the rack.No left/right motion just top/bottom in out motion it will be upper links/lower arm and or the kingpin assembly.
Kind of a process of elimination.The problem is the multiplication effect on the wheel>tire as only 0.006" from my kingpin and king pin bearings translated to 0.1" at the tire edge.
The reason they changed the kingpin mount was that the kingpin is harder than its tapered mount so it wears the seat away and just a new kingpin may still allow excess slop. I was lucky my mount was not damaged enough just the kingpin......as these parts are only $80.
On the drivers side the mounting arm for upper part of king pin was bent allowing excess negative camber [-0.3 degrees] and the pin had worn the bearing seat.
The problem is once vibration starts or tires rotors are driven on vibrating it starts to wear rubber components, once the rubber is worn, wear may proceed to the kingpin and bearings.
Just like shocks the wear is small but steady and owners get use to the feeeling. Tech's never take a car on the highway at speed for an hour [you pay] so they don't feel all the problems ina 5 minute around the block test drive..........plus many never ride in a perfect 90-93 so they have no comparison.
Unfortunately rides like new means all new parts and the ones you skimp on are sure to be the culprits.
It costs about 66% more to R&R a LS400 completely changing the same type parts..........for once Q design pays off but the LS parts last longer by at least a third to 50% so it is a wash on 200-250,000 miles.
If a $50,000 car really cost $35,000 to make and it has depreciated to $5,000, is the $30,000 difference what you would really have to spend to make it like new again. Plus of course the routine maintenance and wear items which can equal $15,000 in 200,000 miles.
The problem is the whole car was assembled and painted in less 30 hours..............yet to change things piecewise a few parts at a time will end up taking 100 hours over 10 years. And the 100% dealer mark up in parts means you pay more than double what the factory paid plus inflation.........close to triple.
My quess is you would spend $45-50,000 if you used all brand new from the dealer.........even retail Junkyard prices to the public are only 50% of new prices.
When I changed my rear subframe and differential [with a junkyard takeout] I ordered the whole rear junk subframe [from a 95Q] and all the parts............sure it cost an extra $500 but but I got $1500 in extra parts [essentially free] to mix and match during the reassembly with my $500 new subframe.
