regular or premium gas? Ser
Buzzman
Car: 2016 Lexus RX 350
2023 Kia Stinger Elite V6 AWD.
Another topic dear to my heart: High test gas or regular?The owners manual on my 03 Ser states that I should be using premium gas. I did that at first, but my wallet was getting pretty light. I've been using regular unleaded for the past 2 years with no noticable difference. Car runs fine.Funny thing is, the Altima uses the same 2.5 engine, and it's marketed as a family sedan, so of course it states that it uses regular unleaded. Fancy that.What is the general consensus out there?Thanks. Great forum by the way. Lots of good info.
R6_240sx
Car: 1997 240SX LE, 2004 YZF-R6, 1980 Celica GT
There's another thread about this already in the 240 section.
zerothread?id=224475
nametakennow
Car: '06 MINI Cooper S
Given that this is a different engine than the KA in several ways, I'm not sure you can apply blanket logic.
Regardless, I don't think you'll notice a huge difference if you drop octane. I certainly won't cause any damage unless it somehow created major pinging. If you're seriously looking to save some cash, try a tank of a lower grade and keep an ear out for how it sounds.
R6_240sx
True, I shoulda put similar, my bad...
I was just trying to make a point that pump gas doesn't usually make a sig. difference.
OneFastStanza
Car: '02 Nissan Sentra SE-R Spec V
'92 Nissan Stanza
'97 Nissan Maxim
'04 Saturn Vue Redline
'04 Ford F250
I personally have always used premium in mine but if you are using a lower octane just do what NTN said
Chris859
Going a little further into that, on an '03, if it did have a small amount of pinging, the computer would just back off the timing to prevent it...
Buzzman
I went through a bunch of threads in the Sentra forum and didn't see anything on this topic, so that's why I asked. I checked the other forum like you said and found it very informative. Thanks.After reading about all this stuff, it brought to mind an article I read in a car magazine from a few years ago (can't remember which one), that had a story on modifying the Spec V for rallying. One thing they mentioned was that the knock sensor was too sensitive and was reacting to external noise. Apparently they removed it and wrapped it up in foam and a cloth and tied it off to the side to keep it out of the way. According to them, it improved performance quite a bit. I don't even know where the sensor is, but it sounds like an interesting experiment.
OneFastStanza
'92 Nissan Stanza
'97 Nissan Maxim
'04 Ford F250
That article was in Sport Compact Car some years back with Dave Coleman's rally SE-R
Buzzman
Hey, I'm impressed that you had that info. I wish I had kept a copy of that issue.Has anyone on this forum actually tried the knock sensor removal trick? Does it work?Most of all though, does anyone know exactly where the sensor is on this engine? I don't have a clue where to look.Thanks.
