Now that's what I expect but that's not what i believe is going on. My log has not been filled out, fluids are exactly the same as when I brought the car in as far as the inspection goes I've no clue they could be doing it or they could have an oil change person that's not a mechanic change oils? The only thing listed on the receipt is 10w40 x5, filter and that's it no other services are listed. I've kept the receipts with the log book so it's there if ever needed. I'll have the tires rotate myself and I may take it in for one more oil change and see if things are any different this time around. Maybe they are giving me the bare bones service since this is my second free oil change.eeshazor wrote:A lot of people do regular maintenance themselves (i.e. oil changes, tire rotations, filter replacements), and that's great. Saves you some money. For the record, tire rotations should be done every other oil change, and oil changes should be done every 3,500 miles. HOWEVER, on whenever you hit a milestone (i.e. 15k miles, 30k miles, 45k miles, etc.), you should absolutely be taking the car to the dealership. It's worth the higher cost to make sure things are done right. My boyfriend works for Nissan, and he's also a UTI graduate, and I asked him if it was his car, would he be taking his car in for his 15k's, etc and he said definitely. For one, they top off ALL fluids , they do a mandatory 27-point inspection which is something that might not get done other places, they do oil change & tire rotation, battery terminal service, and inspect anything you might have questioning about. They also fill out your service charge log. And also, the techs & mechanics at Nissan go through strict training on all cars Nissan, so of course they're gonna be at least a little more efficient with your carHope this helps.
I had thought about that lol I might just do it too just to get in some practice swapping out a spare on this car should I ever need to pull it on the side of the road at some point although am sure it can't been any different that doing it on a ford.Promise Land wrote:if you want to rotate your tires, you can use the jack the car comes with use the spare to replace one of the tires while you take the other off and replace it with the original you took off.
I had five free oil changes given to me by my dealership, and they always topped off any fluids and checked my tire pressure for me. I still can't justify spending $50 for an oil change for them to check my tire pressure or top off any fluids. I just do all that at home now when we change her oil.aidan80 wrote:Maybe they are giving me the bare bones service since this is my second free oil change.
