4drsleeper wrote:I would have told you exactly what the guy at Infiniti said. The gas shouldn't do any harm other than a little lack in performance but I wouldn't push it until you run that tank out. I would drive until you're about empty before filling up again.
He is in a G37x which means that if he was doing this as a matter of practice that just maybe Infiniti would void the warranty of related repairs.marlin29311 wrote:You can run your car at 100% 87 octane if you want...there are a couple members that do so anyway with no issues at all. However, you will be in a state of decreased performance, as the engine has to compensate for the lower octane rating to make sure that it doesn't knock.
All in all, you're fine - no worries. But be sure to try and take the tank all the way down and then use premium again!
PhilBawdyPhilBawdy wrote:I went to a local HESS station to fill up yesterday, I asked for premium, was to busy looking at the detail job I had done earlier, when I realized the dumb a** was pumping regular into my tank. I had a quater tank when I pulled in, he pumped 4.5 gallons of regular before I noticed, and pumped the remaining space with premium. The premium topping wasn't much at all.I stopped by my dealership which was a block down, the service guy, who runs paperwork but owns a G37, said that it might act strange and not to accelerate hard until I work the gas out, but shouldn't hurt the vehicle.
I trust this forum for truthful answers more than a dealership, which would tell me what I wanted to hear. Is there any cause for concern or should I take any action to prevent damage/performance issues?
Thanks to all for your help, this topic and previous ones.
That is why I posted the fuel requirements from the 2009 manual since the poster stated he had a 37x. I think many did not pick up on what the poster was possibly driving. To me the issue is that while he should be ok with this amount in the tank he should follow the recommendations so as not to violate any provisions in the warranty which could haunt him down the road. I believe once an owner knows of a problem he needs to do what is necessary to mitigate it.EZcheese15 wrote:You should be fine with a mixed tank of 87/91+. However, just to clarify with most people responding to this post:
The VQ37 and VQ35 are quite a bit different. The owners manual for the 08 G37 lists two different fuel requirements for the sedan (3.5) vs. the coupe (3.7).
The 3.5 can run on 87, and the knock sensor will compensate for it. You will just have decreased performance. The 3.7 does not have the same safety margin built into it. It needs 91. But like quoted above, you will be ok to mix with 87 temporarily so long as you take it easy.
Different parts of the country have different octane levels as their "premium." For example, in CA the highest octane you can buy is 91. However, some states, such as PA, sell as high as 94. The reason car manufacturers only design to run a car on 91 and not 92+ is because you can't get 92+ in every state.G37 Man wrote:Okay I have a question,how many gas stations sell 91 Octane fuel?
I know of only one Sunoco, everyone else sells 92,93 Octane and of course mid grade 89 or regular 87.
Will 89 Octane affect the G37 over a period of time?
For example a car is low on oil for any reason and the owner knows it. He takes it out in this condition and drives at high speeds and the engine blows. The owner did not mitigate the problem and from what I read in a warranty just may have given up coverage.
Perry
I think it is a good comparison, the same with transmission fluids, etc. The reason is not so much that damage will happen if you put in transmission fluid a instead of b or oil a instead of oil b or gas a instead of gas b. it comes down to the requirements as stated in the warranty.telcoman wrote:
Perry
I don't think driving a vehicle that is low on oil is a good comparison with the grade of gasoline octane when discussing a warranty issue?
Telcoman
I've already discussed this with the service department the last time I was there with my G35G37 Man wrote:But what I don't like is when a car is sold by a Mfg such as Nissan/Infiniti and they tell you after you purchase the car that you need to use our oil/Ester or you runs the risk of damage to your car.
This must be discussed at the time of purchase and when ads are run on the G37,they should not be allowed to sell that car with out disclosing that very important part of the buying experience.
would it make a difference in buying the car? maybe for some it would.
I was going to put in Royal Purple,now I will not chance it or any other oil for that matter.
I don't believe it states anywhere that you have to use Ester, only that it is recommended. It does state you have to use spec oil. One benefit about using the Ester however (other than it sounds like oil I would want to use) is that it is recommended. If you do what is required and what is recommended then it takes the wind out of the dealers sails if trouble comes up.G37 Man wrote:I can understand the warranty as it relates to Gas and Octane rating as it affects the G37.
I asked my Infiniti dealer's service department what brand they put in when I brought my G37 in for an oil change. They replied that they use bulk Valvoline. If that would void the warranty, I can't believe they would use it.G37 Man wrote:... you need to use our oil/Ester or you runs the risk of damage to your car.
I was told ester oil was recommended because some owners complained about valve noise when engines were cold. The variable valve timing is the cause but the noise will go away as the engine reaches operating temperature.If I owned one the noise would not bother me having owned a previous diesel engine.G37 Man wrote:Then why did a service bulletin come out for the G37 saying to use Ester Oil?
The 08 model did not have that listed as required but the 09 did and in Aug 08 Infiniti came out with the service bulletin on the 08.
By the way I have not gone with the Ester oil but staying with standard 5-30Nissan Oil,I can't complain it only cost $29 for the oil change with my Infiniti dealer.
As long as it is actually valve noise and no valve damage occurs. My experience is there is little difference in many engines between valve noise and piston slap and both tend to disappear when warmed up.telcoman wrote:
What would bother me more is the price of the oil.
Telcoman
I agree however, there are recomentations in the warranty booklets to change certain fluids more than is really necessary.pfarmer wrote:
`If you keep a car for 50k why worry from an economic standpoint. If you are going to keep it for 200k then does the added cost of this oil make sense compared to the alternative? Pretty much all fluids for your car can be view as insurances with different premiums and different coverage.
Perry
I only lost one differential out of the 30-40 cars I have owned (need to recount them sometime for a final tally). On that car it was a matter of it going underwater and even then most of the noise was from axle bearing instead of differential although it was a little hard to tell exactly how much was from which source. The only reason I got rid of the car was this and the fact it was getting really noisy at times (engine wise) with over 320k on the odometer.telcoman wrote:
For example, I've never in my life changed differential fluid on any vehicle even after putting on close to a quarter million miles and never had a differential failure. There are posts on here from those that do.
I also happen to have an engine in my G35 that uses oil. It has used oil from the first day I purchased my G on 12/31/05
Does it bother me?
NO!
I did the consumption test at the dealer after they came out with the service bulletin and my engine only used 12mm instead of the 18mm per 3 thousand miles to qualify for a new engine.
Currently after three thousand miles it uses about a quart so I just change it.
Now that oil consumption would certainly drive some owners crazy but not I because I'm one of the old farhts crazy enough to change my own oil every three thousand miles no matter what the owners manual says.
Telcoman
