lpreston »
https://forums.nicoclub.com/lpreston-u99676.html
Wed Aug 20, 2008 2:14 am
Clean the badge off with a light Scotchbrite pad and dishwashing soap. Let it dry. I had an old synthetic sanding pad (I'm unsure of the grit). Its just abrasive enough to scratch the surface. Keep the strokes all in the same direction. Once you are happy with the results, wash the part again in the soap solution and let dry. Then 3 light coats with a satin clearcoat.
