Refilling Transmission Fluid
buddy
Any tricks to properly changing transmission fluid in a '96 Q? Can I take it to an instant oil change place without much worry? Does it take a special kind of fluid?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
are you just wanting to do a drain and refill? if you do that youll only get about 4-5 out of the 14 quarts the trans holds...
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
http://www.bgfindashop.com
Quite a few posts on ATF fluid exchange, auxiliary ATF coolers, ATF fluids.
Read tehm frist and you will be forearmed.
buddy
Wow! 14 quarts! Will it not be worth it to do a fluid exhange?
elwesso
2007 BMW M Coupe
If your trans fluid hasnt been changed in a while id do a mechanical exchange.. You can also do the drain/refill deal (drain pan, fill up, run car for 2 mins, repeat until you go through say 18-20 quarts), however if your not inclined to do it yourself a mechanical exchange is by far the easiest....
My local shop will do a full flush with 16 quarts for $70 including valvoline fluid, so I find that hard to beat. Not synthetic, but if you replace it yearly therse no problems!!! $70/year to keep your trans fluid AS NEW is a small price to pay compared to $2500 installed for a new one!
