es.biggs wrote:So, to do the plastigage the right way, you need to find where the crank is closest to the top of the center bearing cap, then make measurements at that position?
Something I can't remember - aren't all measurements supposed to be made at the same time? In other words, lay plastigage on the crank at every main bearing and torque all caps down properly, then remove the caps and read the measurements?
Yes, you find the highest point and measure from there. The center should be checked because it's most likely where buckling occurs, most deflection. Think about a thin diameter cylinder shaft with two unbalanced flywheels on each end of it... spin the shaft and the vibrations begin. The flywheels will wobble in the axis direction, the shaft transfers that deflection, but it has mass on both sides...which resists the deflection. Finally resulting it buckling in the center to maintain it's rotational movement.
You can check all the high points of all the journals... but can you imagine unbolting and rebolting the main caps for the number of journals the engine has?! At most I would do it twice, the center and the outside edges. (maximum for VG30 with 4 mains, but it's a time consuming with a straight 6 with 7 journals..)
Your measurements are not going to be the same.. that's why there is a tolerance. The most accurate method is to use a bore gauge, then use the plastigauge to true clearance... using it at 3 points.. the ends of the crank and the center.
Not much you can do to change your clearance. Most just buy ACL and drop them in check see if you are in tolerance. Nissan already gave you specs for your engine... it's those numbers on the crank.. and bottom face of the block. Those are numbers to determine grades of bearings, different thicknesses. For instance you take the first number off the crank.. 1.. and then the block...0. Add them up 1+0 = 1... which means it uses a grade 1 bearing. (it's in the FSM....) You can take it further and order the bearing to you want in tolerance from your initial measurement from the bore gauge.
You can get away with buying ACL bearings. I just like to put a little more effort in mine.
Red... best place to start.. is buy a paper copy of the FSM and read it.
